I have a situation where a wood framed structure (2x6 studs at 16" o-c, 2x6 top/bottom plates) was built with interior load bearing walls that were fastened to slab with masonry cut nails about 32" o-c. The inspector has asked for verification that no other fastening (i.e., bolts) are required. In looking into this, I find no indication in the IBC or NDS that cut nails exist (as far as Code as concerned).
Does anyone have any experience with this? Are cut nails a valid way to fasten a wall bottom plate to a concrete slab per any code, and is there any code values? From a design standpoint there would be a nominal 5 psf lateral load, so not much capacity required to resist lateral forces at the base of the wall.
