Code to open a new part in solidwords 2009 from excel vba 1
Spurs
297
I have been able to program Solidworks VBA to be able to create a 3D moldel in solidworks.
Now I would like to be able to do the same by launching it from Excel VBA.
I am having problems with the syntax to open up a new part in solidwors from excel vba
does anyone have similar code that is working to use as an example of the syntax?
It doesn't really matter what program has the VBA in it - Visio, Excel, Word, PowerPoint, whatever. All you need to do is get the SldWorks.SldWorks object that you get at the beginning of every SW macro with something like:
Set swApp = Application.SldWorks
except you use GetObject (if you know SW is open) or CreateObject if SW might not be open.
-handleman, CSWP (The new, easy test)
I recorded the following macro using Solidworks to create a simple cylinder.
I moved the macro to excel and tried to run it.
when I run it using excel vba, I get the error
object does not support this property or method
on the line
which is the line you said we need.
any ideas?
the code is below
' C:\Users\Office\AppData\Local\Temp\swx5468\Macro1.swb - macro recorded on 02/27/11
Dim swApp As Object
Dim Part As Object
Dim boolstatus As Boolean
Dim longstatus As Long, longwarnings As Long
Sub main()
Set Part = swApp.NewDocument("C:\Program Files\SolidWorks Corp\SolidWorks\lang\english\Tutorial\part.prtdot", 0, 0, 0)
swApp.ActivateDoc2 "Part4", False, longstatus
Set Part = swApp.ActiveDoc
Dim myModelView As Object
Set myModelView = Part.ActiveView
myModelView.FrameState = swWindowState_e.swWindowMaximized
boolstatus = Part.Extension.SelectByID2("Front", "PLANE", 0, 0, 0, False, 0, Nothing, 0)
Part.SketchManager.InsertSketch True
Part.ClearSelection2 True
Dim skSegment As Object
Set skSegment = Part.SketchManager.CreateCircle(0.03616, 0.021024, 0#, 0.027669, 0.014151, 0#)
boolstatus = Part.Extension.SelectByID2("Arc1", "SKETCHSEGMENT", 0.03454268968685, 0.03153595505618, 0, False, 0, Nothing, 0)
Dim myDisplayDim As Object
Set myDisplayDim = Part.AddDimension2(-0.007505250388061, 0.04265440074906, 0)
Dim myDimension As Object
Set myDimension = Part.Parameter("D1@Sketch1")
myDimension.SystemValue = 0.0123
Part.ShowNamedView2 "*Trimetric", 8
boolstatus = Part.Extension.SelectByID2("D1@Sketch1@Part4.SLDPRT", "DIMENSION", 0, 0, 0, False, 0, Nothing, 0)
Dim myFeature As Object
Set myFeature = Part.FeatureManager.FeatureExtrusion2(True, False, False, 0, 0, 0.014, 0.01, False, False, False, False, 0.01745329251994, 0.01745329251994, False, False, False, False, True, True, True, 0, 0, False)
Part.SelectionManager.EnableContourSelection = False
End Sub
In the VBA editor you will need to go to Tools->References and pick all the SolidWorks stuff.
Sorry I wasn't so clear. Application.SldWorks only works from SolidWorks. From any other program you need to use GetObject or CreateObject, or the New keyword.
Here's an Excel sheet that will attach to a running instance of SW or (if one does not exist already) start a new one, then start a new part file.
 http://files.engineering.com/getfile.aspx?folder=3685b27c-ddd1-4a59-be16-dc69f6f17287&file=StartSWPart.xls
Hi Handleman
Thank you so far for your help. Your macro has opened up solidworks, but when I add on the rest of the macro that was recorded by solidworks itself, nothing else happens.
Ie solidoworks opens and that it - no errors are reported
here is the full code as I am trying to run from excel
Sub StartNewPartFromExcel()
Dim swApp As SldWorks.SldWorks
Dim Part As Object
Const ERR_APP_NOTFOUND As Long = 429
On Error Resume Next
Set swApp = GetObject(, "SldWorks.Application")
If Err.Number = ERR_APP_NOTFOUND Then
Set swApp = New SldWorks.SldWorks
swApp.UserControl = True
End If
swApp.NewPart
Set swApp = Nothing
' from here down, the macro comes from SW
End Sub
any thoughts as what I still need to do to get it to draw and extrude?
Sorry, I guess that once again I was unclear.
"Set swApp = Application.SldWorks" ONLY WORKS WHEN THE CODE IS RUN IN A SOLIDWORKS MACRO. IT WILL NEVER WORK FROM EXCEL. IF YOU PUT THAT LINE ANYWHERE IN AN EXCEL MACRO IT WILL NEVER, EVER WORK.
Read the code a little bit.
My code sets swApp = Nothing, which is good practice once you're done using any object. However, if you want to tack on a bunch of code after it, you aren't done using it. So you shouldn't set it = Nothing until the end of your tack-on code. And you shouldn't try to set it = something with the above line of code either.
You should also put in the line "On Error Goto 0" in the spot where you take out "Set swApp = Nothing". Then you will be told where the rest of your errors are.
Handleman
Your suggestions worked fantastic
Thank you so much for your help
