Hey Cowski
I mention you specifically because you were the one who did this for me so I figured you would be the most knowledgable on it.
You might remember that the following code will let you select an edge to a component and place a label and the label would draw from an attribute on that component.
I am looking to make two new codes, each with a different change.
1) The only change would be to copy and paste the information from the attribute and not associate it with a code linked to it.
The reason I need this is because we have files now that we extract edges from the bodies and we turn the layer with the actual component off in the drafting view. When we do that and update the view, the labels become dissasociated.
If this is a very difficult change, we have found a work around. So even though this change would make the job easier from the start, its not the end of the world if it is asking too much right now.
2) On a separate code, I would ask for the same change if possible (again, not the end of the world if you cant at this time) plus I would like to select an actual "point" in the component instead of the edge of a component. It would draw the "ID" attribute from the object of the point instead of from the component.
We have weld spot files that are basically just a whole bunch of points. Each point has an "ID" attribute in its properties. We have a label program that already does the job but it is a GRX file that is impossible to read or change and it forces specific fonts and stuff. So every label we create has to have the font type, size and aspect ratio changed to fit GM's standards. I am hoping this would not be a major update to this code so that we can set the font in preferences and all of the labels would be correct as we make them.
I and a leader here have moved into a new area of the company to help get a hot job out and we were shocked at the amount of time that could be saved in the future with a few buttons for repeated actions. These two are two of the biggest ones on the list.
Code:
Option Strict Off
Imports System
Imports System.Collections.Generic
Imports NXOpen
Imports NXOpen.UF
Module Module2
Dim theSession As Session = Session.GetSession()
Dim theUfSession As UFSession = UFSession.GetUFSession
Dim theUI As UI = UI.GetUI()
Dim workPart As Part = theSession.Parts.Work
Dim displayPart As Part = theSession.Parts.Display
Dim lw As ListingWindow = theSession.ListingWindow
Dim lg As LogFile = theSession.LogFile
Dim noteLength As Double
Dim noteHeight As Double
Dim alignPos As Annotations.AlignmentPosition = Nothing
Dim curStubLength As Double
Dim curPickEnd(1) As Double
Sub Main()
lg.WriteLine("~~ NXJ label component ~~")
lg.WriteLine("800c0a41-139c-4682-b37f-cfd398de402c")
lg.WriteLine(" timestamp: " & Now)
If IsNothing(theSession.Parts.Work) Then
'active part required
lg.WriteLine(" no active part, exiting journal")
Return
End If
lw.Open()
Const undoMarkName As String = "create component labels"
Dim markId1 As Session.UndoMarkId
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Visible, undoMarkName)
Dim myDraftingCurve As Drawings.DraftingCurve = Nothing
Dim myView As View = Nothing
Dim myPickPt As Point3d
While SelectDraftingCurve(myDraftingCurve, myPickPt, myView) <> Selection.Response.Cancel
'lw.WriteLine("curve tag: " & myDraftingCurve.Tag.ToString)
Dim obj_coords As Point3d = Nothing
obj_coords = GetPositionOnObject(myDraftingCurve, myView, myPickPt)
Dim obj_coords_dbl(2) As Double
obj_coords_dbl(0) = obj_coords.X
obj_coords_dbl(1) = obj_coords.Y
obj_coords_dbl(2) = obj_coords.Z
theUfSession.View.MapModelToDrawing(myView.Tag, obj_coords_dbl, curPickEnd)
Dim parentCount As Integer
Dim parents() As Tag = Nothing
theUfSession.Draw.AskDraftingCurveParents(myDraftingCurve.Tag, parentCount, parents)
Dim someComp As Assemblies.Component = Nothing
'lw.WriteLine("parent count: " & parentCount.ToString)
For Each temp As Tag In parents
Dim tempObj As NXObject = Utilities.NXObjectManager.Get(temp)
'lw.WriteLine("parent type: " & tempObj.GetType.ToString)
'lw.WriteLine("is occurrence: " & tempObj.IsOccurrence.ToString)
If tempObj.IsOccurrence Then
'lw.WriteLine("owning component: " & tempObj.OwningComponent.DisplayName)
someComp = tempObj.OwningComponent
Else
'lw.WriteLine("owning part: " & tempObj.OwningPart.Leaf)
End If
Next
If IsNothing(someComp) Then
lw.WriteLine("no component selected")
Return
End If
'lw.WriteLine("comp name: " & someComp.Name)
'lw.WriteLine(myPickPt.ToString)
'lw.WriteLine("selected from view: " & myView.Name)
'Dim compToolID As String = GetComponentAttribute(someComp, "DB_PART_NO")
'Dim compPartName As String = GetComponentAttribute(someComp, "DB_PART_NAME")
'Dim compClassification As String = GetComponentAttribute(someComp, "TOOL_CLASS")
'lw.WriteLine("compToolID: " & compToolID)
'lw.WriteLine("compPartName: " & compPartName)
'lw.WriteLine("compClassification: " & compClassification)
Dim curLetterPrefs As Annotations.LetteringPreferences = theSession.Parts.Work.Annotations.Preferences.GetLetteringPreferences
alignPos = curLetterPrefs.AlignmentPosition
Dim userSymbolPreferences1 As Annotations.UserSymbolPreferences
userSymbolPreferences1 = theSession.Parts.Work.Annotations.NewUserSymbolPreferences(Annotations.UserSymbolPreferences.SizeType.ScaleAspectRatio, 1, 1)
Dim curDimPrefs As Annotations.LineAndArrowPreferences = theSession.Parts.Work.Annotations.Preferences.GetLineAndArrowPreferences
curStubLength = curDimPrefs.StubLength
MeasureNoteLength(MakeLabelText(someComp))
'select point for label
Dim labelPosition As Point3d = SelectScreenPoint()
'lw.WriteLine("label position: " & labelPosition.ToString)
'UF_DRF_create_label
AddComponentLabel(someComp, myDraftingCurve, myView, obj_coords, labelPosition, MakeLabelText(someComp))
End While
lw.Close()
End Sub
Function SelectDraftingCurve(ByRef theDraftingCurve As Drawings.DraftingCurve,
ByRef pickPt As Point3d,
ByRef selView As View) As Selection.Response
Dim message As String = "Drafting Curve:"
Dim title As String = "Select a drafting curve"
Dim scope As Integer = UFConstants.UF_UI_SEL_SCOPE_ANY_IN_ASSEMBLY
Dim response As Integer
Dim draftingCurveTag As Tag = Tag.Null
Dim view As NXOpen.Tag
Dim cursor(2) As Double
Dim ip As UFUi.SelInitFnT = AddressOf mask_for_curves
Dim cursorView As Integer
theUfSession.Ui.AskCursorView(cursorView)
theUfSession.Ui.SetCursorView(0)
theUfSession.Ui.LockUgAccess(UFConstants.UF_UI_FROM_CUSTOM)
Try
theUfSession.Ui.SelectWithSingleDialog(message, title, scope, ip,
Nothing, response, draftingCurveTag, cursor, view)
theDraftingCurve = Utilities.NXObjectManager.Get(draftingCurveTag)
selView = Utilities.NXObjectManager.Get(view)
pickPt.X = cursor(0)
pickPt.Y = cursor(1)
pickPt.Z = cursor(2)
If draftingCurveTag <> Tag.Null Then
theUfSession.Disp.SetHighlight(draftingCurveTag, 0)
End If
Finally
theUfSession.Ui.UnlockUgAccess(UFConstants.UF_UI_FROM_CUSTOM)
theUfSession.Ui.SetCursorView(cursorView)
End Try
If response <> UFConstants.UF_UI_OBJECT_SELECTED And
response <> UFConstants.UF_UI_OBJECT_SELECTED_BY_NAME Then
Return Selection.Response.Cancel
Else
Return Selection.Response.Ok
End If
End Function
Function mask_for_curves(ByVal select_ As IntPtr, ByVal userdata As IntPtr) As Integer
Dim num_triples As Integer = 4
Dim mask_triples(3) As UFUi.Mask
mask_triples(0).object_type = UFConstants.UF_line_type
mask_triples(0).object_subtype = 0
mask_triples(0).solid_type = 0
mask_triples(1).object_type = UFConstants.UF_circle_type
mask_triples(1).object_subtype = 0
mask_triples(1).solid_type = 0
mask_triples(2).object_type = UFConstants.UF_conic_type
mask_triples(2).object_subtype = 0
mask_triples(2).solid_type = 0
mask_triples(3).object_type = UFConstants.UF_spline_type
mask_triples(3).object_subtype = 0
mask_triples(3).solid_type = 0
theUfSession.Ui.SetSelMask(select_,
UFUi.SelMaskAction.SelMaskClearAndEnableSpecific,
num_triples, mask_triples)
Return UFConstants.UF_UI_SEL_SUCCESS
End Function
Function GetComponentAttribute(ByVal theComp As Assemblies.Component, ByVal attributeTitle As String) As String
If theComp.HasUserAttribute(attributeTitle, NXObject.AttributeType.String, -1) Then
Return theComp.GetUserAttributeAsString(attributeTitle, NXObject.AttributeType.String, -1)
Else
Return Nothing
End If
End Function
Function SelectScreenPoint() As Point3d
'Allow user to interactively pick the point where the annotation
'will be placed.
'This Function needs Sub MotionCallback() to work properly.
Dim myScreenPos(2) As Double
Dim theViewTag As Tag = theSession.Parts.Display.Views.WorkView.Tag
Dim theResponse As Integer
theUfSession.Ui.SpecifyScreenPosition("pick a point", AddressOf MotionCallback, Nothing, myScreenPos, theViewTag, theResponse)
If theResponse = UFConstants.UF_UI_PICK_RESPONSE Then
Return New Point3d(myScreenPos(0), myScreenPos(1), myScreenPos(2))
Else
Return Nothing
End If
End Function
Function GetPositionOnObject(ByVal obj As DisplayableObject, ByVal aView As View, ByRef coords As Point3d)
Dim guess1 As Double() = New Double(2) {}
Dim pt1 As Double() = New Double(2) {}
Dim pt2 As Double() = New Double(2) {}
Dim min_dist As Double
Dim loc_view As Point3d = MapAbs2View(aView, coords)
Dim sp_view As New Point3d(loc_view.X, loc_view.Y, loc_view.Z + 1000)
Dim ep_view As New Point3d(loc_view.X, loc_view.Y, loc_view.Z - 1000)
Dim sp_abs As Point3d = MapView2Abs(aView, sp_view)
Dim ep_abs As Point3d = MapView2Abs(aView, ep_view)
Dim line1 As Line = theSession.Parts.Work.Curves.CreateLine(sp_abs, ep_abs)
line1.SetVisibility(NXOpen.SmartObject.VisibilityOption.Visible)
line1.RedisplayObject()
theUfSession.Modl.AskMinimumDist(obj.Tag, line1.Tag, 0, guess1, 0, guess1, min_dist, pt1, pt2)
Dim markId2 As Session.UndoMarkId = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "Delete")
theSession.UpdateManager.AddToDeleteList(line1)
theSession.UpdateManager.DoUpdate(markId2)
Return New Point3d(pt1(0), pt1(1), pt1(2))
End Function
Function MapView2Abs(ByVal aView As View, ByVal coords As Point3d)
Dim vmx As Matrix3x3 = aView.Matrix
Dim vw() As Double = {0, 0, 0, vmx.Xx, vmx.Xy, vmx.Xz, vmx.Yx, vmx.Yy, vmx.Yz}
Dim abs() As Double = {0, 0, 0, 1, 0, 0, 0, 1, 0}
Dim mx(11) As Double
Dim irc As Integer
Dim c() As Double = {coords.X, coords.Y, coords.Z}
theUfSession.Trns.CreateCsysMappingMatrix(vw, abs, mx, irc)
theUfSession.Trns.MapPosition(c, mx)
MapView2Abs = New Point3d(c(0), c(1), c(2))
End Function
Function MapAbs2View(ByVal aView As View, ByVal coords As Point3d)
Dim irc As Integer
theUfSession.Trns.CreateCsysMappingMatrix(abs, vw, mx, irc)
MapAbs2View = New Point3d(c(0), c(1), c(2))
End Function
Sub MotionCallback(ByVal pos() As Double,
ByRef motion_cb_data As UFUi.MotionCbData,
ByVal client_data As System.IntPtr)
'This sub will be called every time a cursor move is detected during the
'SpecifyScreenPosition function.
'The parameters motion_cb_data and client_data are not used in this implementation,
'but the Sub must have the same signature as UFUI.MotionFnT to work properly.
'disable (for now)
'Return
Dim wView As NXOpen.View = theSession.Parts.Display.Views.WorkView
Dim topLeft(2) As Double
Dim topRight(2) As Double
Dim botLeft(2) As Double
Dim botRight(2) As Double
'Dim labelWidth As Double = 20
'Dim labelHeight As Double = 5
'draw rectangle(s) to represent tabular note boundary
'Select Case alignPos
' Case Is = Annotations.AlignmentPosition.TopLeft
' 'draw rectangle to the right and down
' 'pos = top left corner
' topLeft(0) = pos(0)
' topLeft(1) = pos(1)
' topRight(0) = pos(0) + noteLength
' topRight(1) = pos(1)
' botLeft(0) = pos(0)
' botLeft(1) = pos(1) - noteHeight
' botRight(0) = topRight(0)
' botRight(1) = botLeft(1)
' Case Is = Annotations.AlignmentPosition.TopRight
' 'draw rectangle to the left and down
' 'pos = top right corner
' topLeft(0) = topRight(0) - noteLength
' topLeft(1) = topRight(1)
' botLeft(0) = topLeft(0)
' botLeft(1) = topLeft(1) - noteHeight
' Case Else 'shouldn't happen
'End Select
'assume mid center alignment position for now
topLeft(0) = pos(0) - noteLength / 2
topLeft(1) = pos(1) + noteHeight / 2
topRight(0) = topLeft(0) + noteLength
topRight(1) = topLeft(1)
botRight(1) = topRight(1) - noteHeight
Dim stubStart(1) As Double
Dim stubEnd(1) As Double
stubStart(0) = pos(0) - noteLength / 2
stubStart(1) = pos(1)
stubEnd(0) = stubStart(0) - curStubLength
stubEnd(1) = stubStart(1)
'for other temp graphics commands, see:
' DisplayOgpArc
' DisplayOgpCircle
' DisplayOgpLine
' DisplayOgpPolyline
theUfSession.Disp.DisplayOgpLine(wView.Tag, topLeft, topRight)
theUfSession.Disp.DisplayOgpLine(wView.Tag, topLeft, botLeft)
theUfSession.Disp.DisplayOgpLine(wView.Tag, botLeft, botRight)
theUfSession.Disp.DisplayOgpLine(wView.Tag, topRight, botRight)
theUfSession.Disp.DisplayOgpLine(wView.Tag, stubStart, stubEnd)
theUfSession.Disp.DisplayOgpLine(wView.Tag, stubEnd, curPickEnd)
End Sub
Sub AddComponentLabel(ByVal theComponent As Assemblies.Component,
ByVal theDraftingCurve As Drawings.DraftingCurve,
ByVal theView As View,
ByVal leaderPt As Point3d,
ByVal originPt As Point3d,
ByVal theText() As String)
Dim markId1 As NXOpen.Session.UndoMarkId = Nothing
markId1 = theSession.SetUndoMark(NXOpen.Session.MarkVisibility.Invisible, "Note")
Dim nullNXOpen_Annotations_SimpleDraftingAid As NXOpen.Annotations.SimpleDraftingAid = Nothing
Dim draftingNoteBuilder1 As NXOpen.Annotations.DraftingNoteBuilder = Nothing
draftingNoteBuilder1 = workPart.Annotations.CreateDraftingNoteBuilder(nullNXOpen_Annotations_SimpleDraftingAid)
draftingNoteBuilder1.Origin.Anchor = NXOpen.Annotations.OriginBuilder.AlignmentPosition.MidCenter
draftingNoteBuilder1.Origin.Plane.PlaneMethod = NXOpen.Annotations.PlaneBuilder.PlaneMethodType.XyPlane
Dim leaderData1 As NXOpen.Annotations.LeaderData = Nothing
leaderData1 = workPart.Annotations.CreateLeaderData()
leaderData1.StubSize = theSession.Parts.Work.Annotations.Preferences.GetLineAndArrowPreferences.StubLength
' leaderData1.Arrowhead = theSession.Parts.Work.Annotations.Preferences.GetLineAndArrowPreferences.FirstArrowType
leaderData1.Arrowhead = NXOpen.Annotations.LeaderData.ArrowheadType.FilledArrow
'lw.WriteLine("first arrow type: " & theSession.Parts.Work.Annotations.Preferences.GetLineAndArrowPreferences.FirstArrowType.ToString)
leaderData1.VerticalAttachment = NXOpen.Annotations.LeaderVerticalAttachment.Center
leaderData1.StubSide = NXOpen.Annotations.LeaderSide.Inferred
draftingNoteBuilder1.Leader.Leaders.Append(leaderData1)
draftingNoteBuilder1.Text.TextBlock.SetText(theText)
' Jog position relocated or jog removed
leaderData1.Jogs.Clear()
Dim assocOrigin1 As NXOpen.Annotations.Annotation.AssociativeOriginData = Nothing
assocOrigin1.OriginType = NXOpen.Annotations.AssociativeOriginType.Drag
Dim nullNXOpen_View As NXOpen.View = Nothing
draftingNoteBuilder1.Origin.SetAssociativeOrigin(assocOrigin1)
draftingNoteBuilder1.Origin.Origin.SetValue(Nothing, nullNXOpen_View, originPt)
draftingNoteBuilder1.Origin.SetInferRelativeToGeometry(False)
' leaderData1.Leader.SetValue(theDraftingCurve, theView, leaderPt)
Dim nXObject1 As NXOpen.NXObject = Nothing
nXObject1 = draftingNoteBuilder1.Commit()
draftingNoteBuilder1.Destroy()
End Sub
Function MakeLabelText(ByVal theComponent As Assemblies.Component) As String()
Dim labelText As New List(Of String)
If theComponent.HasUserAttribute("DB_PART_NO", NXObject.AttributeType.String, -1) Then
Dim associativeText1 As Annotations.AssociativeText
associativeText1 = workPart.Annotations.CreateAssociativeText()
labelText.Add(associativeText1.GetObjectAttributeText(theComponent, "DB_PART_NO"))
associativeText1.Dispose()
End If
' If GetComponentAttribute(theComponent, "TOOL_CLASS").ToUpper = "COMM" Then
' Dim associativeText1 As Annotations.AssociativeText
' associativeText1 = workPart.Annotations.CreateAssociativeText()
' labelText.Add(associativeText1.GetObjectAttributeText(theComponent, "DB_PART_NAME"))
' associativeText1.Dispose()
' End If
Return labelText.ToArray
End Function
Sub MeasureNoteLength(ByVal noteText() As String)
markId1 = theSession.SetUndoMark(Session.MarkVisibility.Invisible, "measure note")
Dim noteOrigin(2) As Double
noteOrigin(0) = 0
noteOrigin(1) = 0
noteOrigin(2) = 0
Dim noteTag As Tag = Tag.Null
theUfSession.Drf.CreateNote(noteText.Length, noteText, noteOrigin, 0, noteTag)
Dim upLeft(2) As Double
theUfSession.Drf.AskAnnotationTextBox(noteTag, upLeft, noteLength, noteHeight)
'lw.WriteLine("note length: " & noteLength.ToString)
'lw.WriteLine("note height: " & noteHeight.ToString)
theSession.UndoToMark(markId1, "measure note")
End Sub
Public Function GetUnloadOption(ByVal dummy As String) As Integer
'Unloads the image immediately after execution within NX
GetUnloadOption = Session.LibraryUnloadOption.Immediately
End Function
End Module
