I have two questions concerning the envelope ASD Steel Code Check.
1. For a few members I am receiving L/r> 300 for tension member.
A few of the members are for monorails and the majority are horizontal braces which are marked tension only.
2. For a couple of beams but mostly double angle vertical braces I am receiving KL/r > 200 for compression members. The vertical braces are marked Euler buckling.
Q1.Why are these warning coming up in the code check versus the stress ratio?
Q2. On double angle vertical braces we provide a minimum of two tie plates. For the double angles I leave the unbraced length as full length but if I change it to the tie plate spacing I do not get the warning. Should I be changing the unbraced lengths to tie plate spacing in RISA?
