Code case 2211 avilable copy
johngladstone
133
Dears
Is there any one can help me and get copy of
Guidance on the application of code case 2211--overpressure protection by systems design
I appressiate in advance for your support
Best regards
John
Code Case 2211 has been incorporated in to the code proper since 2008. If you have access to the code, see section UG-140.
Dears
Thank you
Actually I looking for following issue
When I need to determine flange class and pipe schudle connect into pressure vessel
It's MAWP 100 psi 200 F
Am I take Allowable and allowable overpressure with factor of safety to determine Design pressure of pipe and Flange class (ANSI 16.5 ) ?
Is case 2211 discusse about this issue or is there any other reference with examples you advice
If there is example clarify your explanation I will fully appressiate
Warm regards
John
ABSA has a good document here
"Everyone is entitled to their own opinions, but they are not entitled to their own facts."
Thanks ironic
For this point I need this clarification point
Is MAWP for vessels cover whole allowable and non allowable over pressure ,
So am I use MAWP to determine Pipe schudle connect into it or use extra F.S ?
Is there any example
Please advice
John
