Hello All,
I'm a fairly new process engineer working at a gas processing plant with a CO2 removal train which uses BASF's aMDEA amine solution for removal. I am working on a project which is looking at our available capacity for CO2 removal and if this can be increased to accommodate additional throughput. One of the options being looked at is to optimise the performance of the train by removing bottlenecks in the process. The way I see it, the bottlenecks are:
Maximum gas velocity through the column
Mass capacity of the amine regeneration heaters limiting CO2 removal capacity
Max amine velocity in piping
I have looked into increasing the amine velocity but due to integrity of the pipes this is not possible. The amine solution has also been replenished so it matches BASF recommended spec. Without physically altering the column or the regen heaters, I'm at a bit of a loss as to other options to explore (aside from bringing another train online).
Does anyone have experience of this type of problem and could point me in the right direction?
