Fellow practitioners of engineering:
A few times now I have encountered masonry bearings fracturing, the face of the wall that is toward the beam span, affecting the face shell of the immediate block or two or three under the beam. It usually a longer span beam during construction. My only explanation is that thermal contraction as pulled on what is a very rigid connection - welded to a bearing plate affixed to wall with embedded studs in grouted cells.
Has anyone dealt with this and resolved this from happening again? I am considering using a slotted hole and finger tight nut on a threaded post welded to the plate that will allow the beam bottom flange to slide in and out of the span. And possibly even greasing the interface.
