I have a quick general questions. For a chilled water system that is closed loop (the supply goes out from the pump through the supply branches which feed different cooling coils and then all feed back to the return branch and back to the pump) when I am calculating the pressure drop to get the head for the pump do I total the loss for each branch or only the worst case branch. I have found conflicting data that says "only the worst branch since the circuits are in really in parallel to each other and the pressure drop per circuit will always be the same as the total zone pressure drop". Just curious here because my thought was the pump had to overcome the total loss from each branch as that is what it is pushing against in essence.
