Closed link connecting system to tank?
jriggs
I am trying to run a 24 hour trial for my system, but the link that connects the water tank to the system always has a status of closed even though i set it as open?? Any sugestions?
John
Are you using WaterCAD? Or other software (which)?
If it's WaterCAD, do you have "controls" set on it? Check the tab after the General tab.
Also, if the link isn't connected on both sides, or if the tank remains empty, it my reflect as closed.
Im using EPAnet. I set my parameters of the tank to full condition. How can I check and see if the tank is emptied when i run my analysis? Also if there might be some other problems, any info would be helpful.
John
