Hi everyone,
I'm modelling a closed conduit which has an ovoidal-like cross section with hec-ras. I'm interested in steady flow, open-channel (not pressurized, at least not for the most part of it) analysis. I modelled the conduit as a lidded cross section. At the moment I just put 3 identical cross sections along a line with a constant slope (simulating a uniform flow) to test the model behaviour and do some roughness calibration. However I have a couple of questions:
- Do I need Preismann slot? (I don't need unsteady computation);
- I'm having trouble using high flows (relatively to the conduit hydraulic capacity); the conduit's shape has a "turning back" rating curve (just like a circular open channel, see image) so the maximum flow capacity is reached at about 90-95% of the total height of the section. It seems that when I use a flow higher than the capacity of the conduit at 100% (which is not the maximum possible) but lower than the maximum possible (as from separately computed uniform-flow rating curve) hec-ras doesn't compute the correct WS height but flows water up the lid (pressurized flow down the lid) even though the conduit would be able to take that flow as open-channel.
P.S.: culverts, bridges, etc., are not an option, I need to know results at various cross sections.
Thank You in advance!
