Eng.Mohamed.ALi
hello guys .
I have an equipment working with ( two ) hydraulic motors ( HAGGLUNDS CB 840), pump SP 355 axial piston pump working in a closed circuit , the problem is the charge pressure is fluctuated and tripped the system, I replaced the pump and the problem still not solved , kindly please I need any supports or ideas, the circuit drawing is attached.
