closed center hydraulics 1
jimbomo
Agricultural
Nov 4, 2010
7
i have a massey ferguson tractor that has closed center hydraulics that i am converting to an open center system, i have an open center pump mounted and working but i know that it will not last long pushing the fluid through so many relief valves. would like to know if a power steering pump from a chevy pickup or car works on a closed center system. if it would work i'd plumb one into the steering and brakes and everything else i have to finish conversion. any help would greatly be appreciated.
AFAIK, power steering pumps are all intended for open center systems.
Mike Halloran
Pembroke Pines, FL, USA
do you know of any closed center pumps that i could run off a pulley to the front that would work?
Such things exist and are available from many sources. They often come with an electric clutch so they can be driven by a belt. Some come with two-groove clutches, so you can piggyback an open center pump alongside the closed center pump. ... which seems to be where you are going. ... I think.
Maybe it's time to put down the wrenches and the credit card, and complete the system design before you buy any more hardware.
Mike Halloran
the best thing is i work at a trash company and i already have most of the valves and pumps that i need just every thing i have is open center. all i really need is a small pump to operate the steering and brakes.
You can make an 'open center pump' into a 'closed center pump' by adding an unloader valve to the pump outlet. If the directional valves are not integrated into the pump meaning you have a bare pump.
Ted
ive thought about that but was not sure it would work, have heard some say that it will build up too much heat
jimbomo, that's how a closed center system uses a fixed displacement pump. The unloader valve directs pump flow back to tank at a low return pressure when the system demand is blocked.
The closed center system pump alternative is a variable displacement pump that is made to stop pumping when the system demand is blocked.
Ted
Put a cooler in the return to tank line so the unloader flow goes through it. That will remove whatever heat the pump put in.
Mike Halloran
Years ago I added an EXTRA power steering pump to a Ford pickup to run a small open center hydraulic circuit. We increased the reservoir capacity by welding another tube to the reservoir. (We "borrowed" a second reservoir and welded two together).
You should calcuate the volume required for implement cylinders and be sure the reservoir is large enough.
I dont think it is a good idea to combine implement functions with steering and brakes.
