I know that closed center and open center valves will possibly use a different valve spool from each other.
Is there any information I can obtain anywhere that could possibly explain how to make a valve both open center and closed center without having different valve spools?
I would like to make a valve that you could use either in closed or open center environment without any modifactions to the valve..
Is this possible?
thanks,
Brent
Is this possible?
thanks,
Brent
