Close NX Part in VB ?
stytgat
Automotive
Mar 29, 2010
15
I am novice in VB and I search to understand why my programm generate an error when i want to close a NX part.
See below a small programm test and the message information about the error.
My small prg test :
Try
Dim MYPart As Part = theSession.Parts.NewDisplay("G:\Temp\Test.prt", Part.Units.Millimeters)
MYPart.Close(BasePart.CloseWholeTree.True, BasePart.CloseModified.CloseModified, Nothing)
Catch ex As Exception
Dim MyWindows As NXOpen.ListingWindow = theSession.ListingWindow
MyWindows.Open()
MyWindows.WriteLine(ex.ToString)
End Try
The error information :
Close part System.NotImplementedException: The method or operation is not implemented.
at Repertoire_STD.Module1.Main() in C:\1_DELPHI\Programmation\VB\Repertoires\Repertoire_STD\Module1.vb:line 425
thanks for your help and best regards,
S. TYTGAT
S. TYTGAT,
Your code executes without error when pasted into a new journal in the NX journal editor and it is "run" - so the syntax is fine.
The boilerplate for an NX journal includes the directive
Code:
Imports System
which implements exception handling.
Is this missing, perhaps?
Regards, Joe
Thanks for your answer but unfortunately, the CODE "Imports System" is already add.
If you have other information to support me, it would be appreciate.
Best regards,
S. TYTGAT
I'm not sure about the close function since I typically use the CloseAll function
C#:
MainSession.Parts.CloseAll(BasePart.CloseModified.CloseModified, null);
Are you sure that your error is being thrown by the close operation?
Line 425 :
Thx and best regards,
S. TYTGAT
I made a quick test journal based on your code, run it and see if you get any errors.
Code:
Option Strict Off
Imports System
Imports NXOpen
Module Module1
    Sub Main()
        Dim theSession As Session = Session.GetSession()
        Dim lw As ListingWindow = theSession.ListingWindow
        lw.Open()
        Dim tempPart As String
        tempPart = IO.Path.GetTempPath
        tempPart = IO.Path.Combine(tempPart, "test.prt")
        Try
            Dim myPart As Part = theSession.Parts.NewDisplay(tempPart, Part.Units.Millimeters)
            MsgBox("part created")
            myPart.Close(BasePart.CloseWholeTree.True, BasePart.CloseModified.CloseModified, Nothing)
            MsgBox("part closed")
            lw.WriteLine(ex.GetType.ToString & " : " & ex.Message)
        Finally
            lw.Close()
        End Try
    End Sub
End Module
www.nxjournaling.com
Always the same error message :
System.NotImplementedException : The method or operation is not implemented.
Thanks,
S. TYTGAT
Are you sure you have you imported the NXOpen namespace?
Are you running any other NX functions in your script that execute just fine, or is the Close operation the only thing your script does?
NX 7.5.4.4 on Win XP64 bits.
I have imported the NXOpen.
I execute differents function without problem in my script. It's only the close operation which don't execute correctly.
But i found another mistake : my script execute correctly on my machine (except the Close function) but do not execute on other computer with error message in attached file.
I am completly lost!
Best regards,
 http://files.engineering.com/getfile.aspx?folder=202c5007-76fd-4790-b7ae-3bfc922000ef&file=error_msg.docx
