clip view to sketch
mystic97z
Aerospace
when I enter a sketch, I have some geometry that is in the way. Is there a way that I can clip the model to the sketch plane? I remember there was a way to do it but I can't find it now.
Hiding the geometry is not sufficient?
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
No. I need to see the part.
Imagine I have a enclosed box, I need to sketch on one of the inside faces. When I create a sketch on that face, I cannot see anything because the outside of the box is in the way.
I know there are workarounds for the exact scenario i'm using here, but I need to know how to actually do it the correct way, as i'm not actually using a box. I know there is a way to do it I used to do it all the time I just can't remember the tool name.
If you are in "Sketch Task Environment" the you can use Section to clip to the sketch plane.
/Mattias
NX5 -> NX12
Testing NX (1847)
I-deas 12, NX I-deas6.6
Solid Works 2017
Matnas that's it!! Thanks
however, it appears that might not be available in nx11 ! I don't have that button
Should be there in NX11. Try using the command finder. It will let you add it to your toolbar
NX9 / TC10.1.2
While in the sketch, open the view tab and use "clip section" (select the plane of the sketch for the clipping plane).
www.nxjournaling.com
