Veer007
- Sep 7, 2016
- 379
Hey Guys, so far I have my w-beam profile as W310X283(W12X190 imperial equivalent), Which has 26.9mm as web thickness seems little high, Can I go with 16mm thick clip angle since I have to provide header angle (double angle) connection, so I have framing angle thickness 16+16=32mm which is higher than beam web thickness, and I am using 1"Ø A325N connection bolts.
or Can I have to increase more than this? One more thing i have to consider the yield stress of w-section is 350 N/mm2 but framing angle has 300 N/mm2
Also as far as i have seen in AISC which doesn't refer more thickness of header angles while beam profile is heavy, please provide your valuable comments for this one.
Thanks in advance!!
Thanks in advance!!
