coldkryten
I recently had to adjust and re-tension a timing belt in a robotic arm. Everything was fine for the first several hours of use, but the belt then started making a noticeable clicking noise. I've re-checked the tension and it is OK. The noise appears to be synchronized with the teeth on the belt, and originates from the region where the belt loses contact with one of the pulleys (reverse the rotation and the noise comes from the opposite side of the pulley.) Turning the system by hand seems smooth and free.
My guess would be a little bit of grease on the belt, I'm wondering if there is any experience or opinion that might point to something more serious.
Cheers,
Mike
Cheers,
Mike
