click ok to termiante
sudhakarn
Automotive
Apr 1, 2013
506
While on opening an assembly in CATIA, am getting below message and the session terminates. We have increased the space available in C drive, and also increased the page file size, but there is no improvement.
Please give a solution at the earliest possible.
This happens only for a particular product. Awaiting your replies.
Sudhakarn,
Try turning on "Work with the cache system" in Options --> Infrastructure --> Product Structure --> Cache Management
Change your Chache Size to 2000 MB for starters.
Restart your session.
You may need to try opening the Product a few times depending on the size. As you open the product, the system will generate a CGR of every part and put all parts into Visualization Mode. To edit a part, or see any Geometric Data, you will need to put the part into Design Mode.
WINdows 7. Previously we were using windows xp.
