Cleaning zinc off 316ss with HCl 1
Murdul
Materials
I want to clean the zinc off a sink roll in a galv line pot using an HCl bath. The roll would be dipped in a 15% HCl concentration to remove the zinc. I am assuming we will still need to machine the surface once we remove the roll? I want to know if the HCl could be corosive enough to cause damage more than 3/1000 below the surface?
thanks EdStainless
We have the HCl already and we want to keep cost to a minimum. right now we machine about 40/1000 off the rolls. so even 10 would be a lot better.
The Metal Finishing Guidebook (p. 395 in 2006 Edn.) lists inhibited, 25 vol% hydrochloric acid at 120oF for stripping zinc from copper & steels.
Also, 15 wt% ammonium nitrate at room T.
Also, can anodic strip in 10 (w/v)% NaOH at 4 V, using steel anodes at room T.
Nitric acid would be best.
If you use HCl I would add an inhibitor to mitigate any corrosion to the SS. You should be a able to get an inhibitor from your supplier of the HCl.
