Hello all,
I have a pet project that is giving me a headache.
I am trying to power a microcontroller circuit from a magneto. The magneto is an AC source which varies in frequency from about 2 to 40 kHz. Waveform is very roughly sinusoidal, with peak voltage varying from about 8 to over 100 volts. Voltage peak increases with frequency.
The microcontroller and associated circuitry (mostly LEDs) will require max 2 A at 5 V.
I have been wrestling with this for a while. So far the best I have come up with is a 1:1 transformer to tap some power without affecting the rest of the system. Then a diode bridge followed by a zener diode and an emitter follower as an active clamp. After this caps and a linear regulator. I am worried the large variation in the AC's peak voltage will cause problems. I would also like to minimize wasted power as much as is possible.
Thanks for your help.
