I'm familiar with the basic theory of operation for class d switching amp's. But, for my project, I am inputting a modulated signal with a 5kHz bandwidth centered at 25kHz. I'm still waiting on some specifics from the customer as to what the signal is and type of modulation. Anway, I have tested the amp with a pure 25kHz sine wave and everything works as calculated (~8% difference), which leads me to believe the amp is fine. But, I'm nowhere close with the modulated signal input. First, I have about a 50% difference in calculated power (25kHz) versus input power across the load (input producing more power). Lowering the on-delay and switching frequency produces even more power across the load, but I still have a 50% difference from calculations. I know it's a modulated input signal, but 50%?!?!? Maybe that's normal, but I can't find any reference material to help back this up. Also, I can't find any resource for calculating/estimating switching frequency. I had it at 300kHz at first so I know I could block it with a filter and still have fairly linear gain across the BW.
Anyway, any insight/thoughts is appreciated.
