We need to create a Smart Audio Amplifier for Home HiFi system. What we want is an equalized volume output with power of 50W. The input will come from a CD player, and the output will enter goto a pair of speakers. In order to do this we plan on at least two stages.. 1. automatic gain control, and 2. the power amplifier.
For automatic gain control, we initially wanted to use a feedback LED,LDR system since from our understanding the intensity transfer/detection is logarithmic, thereby providing good compression of our signal (hence volume equalization). With this circuit, we planned to compress the amplitude of the signal to a known size, and then amplifying the compressed wave in the power amp. Given that the signal is compressed enough, all sources should be equalized to approximately the same volume. We hear that this might not be such a good idea, and that there is a much easier way to accomplish AGC... any ideas?
A few things to keeep in mind... the system we desire to build needs to be able to work on all frequencies. The feedback system controlling the volume of the input also needs to be fast.
As far as the power amp we hear class-E amplifiers are quite simple and very efficient. However, we haven't been able to find much information on these online...
Any help would be very much appreciated
Thank you!
Thank you!
