CLASS 600 RAISED FACE FLANGE AND LARGE MALE FLANGE
SNAVASBRUNEL
QA
Can I use 8" 600 class raised face flange instead of 8" 600 class large male flange?
I couldn't find any difference in dimensions of both flanges
Anybody can please give an answer for this?
What spec is the flange? Connecting to what?
“What I told you was true ... from a certain point of view.” - Obi-Wan Kenobi, "Return of the Jedi"
Acc. to ASME B16.5 Table II-4 Large Male is same as Raised Face.
Per ISO-4126, only the term Safety Valve is used regardless of application or design.
Hi all thanks for the swift reply
As per isometric sheet, a Large female flange(pipe WN flange-8" x 600)connected to a gate valve with 8"x 600 large male WN flange..
We are going to replace this valve. We have a valve in stock but it is RF Flange with same spec of 8"x 600 Large male flange valve..
so can I use RF face gate valve instead of LMF gate valve..spec is matching only difference in faces
