does any one have an explication for the expression of HG in 24-3 of Appendix 24, ASME VIII Div. 1?
Actually I don't understand why the term Hp is being subtracted there, I expect only H to be subtracted as the gasket get unloaded
by the force H as the pressure is applied (in analogy to the expression HG in Appendix 2 from the same code).
Does any one know any reference as paper or technical report behind this appendix?
Thank you
Ali
Thank you
Ali
