I would like to share this information.
About 400 small cast 316L parts were pickled and passivated before receiving. The parts require additional work by grinding. Rather than send them back to the foundry (not their problem anyway)it was decided to passivate the parts in-house. It was decided to try citric acid rather than nitric acid.
After a little research it seems about 15% strength at 80 deg. for 1 hour is the recommended treatment and that periods of longer immersion risk surface speckling.
My own observation was that the ground surface edge appearance changed very little, in fact there appeared to be neglible change. Very unimpressive. We decided to increase the temp and immersion time but also add a detergent to remove possible oil contaminants.
The strength was left at 15%, the temperature was raised to about 98 deg C (simmer), about 1/2% dishwashing detergent added and the parts left to simmer for 24 hours in an aluminium container, but resting on a sheet of G10.
The appearance, at least colorwise, of the ground parts now resemble the original P&P.
