Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
Crvasu said:In 2009 standard never seen circular runout used with basic angle. All I can find are with plus-minus angle.
ASME Y14.5.1M-1994 para. 6.7 said:Nominal diameters, and (as applicable) lengths, radii, and angles establish a cross-sectional desired contour having perfect form and orientation. The desired contour may be translated axially and/or radially, but may not be tilted or scaled with respect to the datum axis.
ASME Y14.5.1M-1994 para. 6.7.1.2 said:The tolerance zone for each circular element on a surface constructed around a datum axis is generated by revolving a line segment about the datum axis. The line segment is normal to the desired surface and is of length t0, where t0 is the specified tolerance.
