Hi, I have two questions regarding the circular pattern.
Does anyone know how to:
1. Create a circular pattern of parts. For example to bolt a lid on to a cylindrical vessel can I put a bolt into one of the holes and then copy it around?
2. Create a circular pattern of holes. I am trying to create a cylinder with many holes equispaced around its circumference but all being drilled towards the centre of the cylinder. I drew one hole using a plane on the cylinder surface but when I copied it around the copied holes were pointing in the same direction as the first and not towards the cylinder axis.
Cheers,
Pete.
Cheers,
Pete.
