You guys aren't thinking.
I have done a lot of application support. If the system is designed right it will run right.
The first questions I ask is
what is the application?
How much mass?
How far must it move?
In how much time?
Is the rod point up, down or horizontal?
Is there an external force to be applied. The mass and external force are two different things.
The OP didn't provide any information to the forum so I don't think he deserves much of an answer.
I would ask on more very important question. What are the cycle times and dwell time at the end of strokes? This is extremely important.
Apparently everyone ignore my previous thread about hydraulic sizing. You can see what I think is important.
So the pump isn't big enough. There is a cure. It is called an accumulator.
The pump only needs to supply the average flow, plus a little more, for the whole cycle if you size the accumulator correctly.
If there is time between the strokes then there is time to re-charge the accumulator.
However, the OP didn't give us this information so when I gave my smart ass response that is all that was deserved.
Look at my thread about hydraulic sizing where I look at the motion profile and the resulting oil demands and how the HPU can be much smaller than the peak oil flow.
The average HPU flow required is a little more than 14 L/min but the peak flow is is 70.7 L/min. You can see the pressure doesn't vary by more than 10%.
One of the purposes of my hydraulic sizing program is to optimize hydraulic design and make it as efficient as possible. It is too bad people ignore it.
I have been doing hydraulic servo control for over 35 years now. I have seen too many projects gone wrong due to poor design or projects not attempted due to lack of a good design.
This thread is more about energy. The pump can supply so much energy over a period of time. The accumulators store energy. As long as the energy required per cycle is not required more than supplied per cycle then the actuator should be able to do what is required. The cycles just need to slow down so the energy of the pump is not exceeded.
This forum is titled "Hydraulic Power Engineering"
I just showed you. Happy now?
Peter Nachtwey
Delta Computer Systems
