a true venturi with entrance and exit profiles can only exhibit a pressure drop associated with frictional losses, and that is minimal,
unless, and that word should be emphasized, unless the fluid undergoes a phase change or in the case of compressible flows reaches sonic velocity at throat conditions.
the situaton is a bit different in the case of flow nozzles, or venturis with a exit angles greater than 45-60Degs. The latter would give you an abrupt pressure drop once you exited the venturi throat.
in your application is is more common to use really thick restriction plates or machined pipe sections, but not venturis
