The definition of choked flow is when a reduction in downstream pressure does not result in an increase in flow through an orifice. In the case of a tiny hole in a pipe if flow becomes sonic it will also be choked.
My question is... if you have choked flow does it necessarily mean you will have sonic flow? i.e. can choked flow exist for sub-sonic velocities?
Thanks,
Rob
Thanks,
Rob
