I use Pro/E for modelling and Pro/FEM for Mesh construction. Pro/FEM allows good control over the mesh at local points with hard points and curves for loading. Models can be meshed using solids or shells and the mesh size controlled locally or globally. Material can also be setup in Pro/FEM using text files. I then export the mesh to Cosmos/M and apply loads and constraints in Cosmos, I never found a way of getting the loads and constraints to export into Cosmos. There is a trick to getting the file into Cosmos because the version I am running insists on naming the mesh export file with a *.cos filename which
Cosmos does not understand, the file created is a GFM format file so you need to rename the file to a *.gfm filename. The Pro/FEM module and Cosmos technique is extremely stable and fast and I have been using this for 5 years now. Pro/FEM can also export to othe FEA systems such as Ansys, Nastran, Patran, Supertab etc. Pro/FEM can also run your preferred solver from within Pro/FEM either online or in the background but I have never used this option. Hope this helps.
