Dear WPR,
Before you start using chloramine, may I suggest you order the case histories and problems associated with trichloramine more correctly referred to as nitrogen trichloride from the Chlorine Institute.
NCl3 (nitrogen trichloride) is formed when the hydrogen atoms on the ammonia molecule are replaced with chlorine atoms. For example:
(1) monochloramine has one chlorine atom and two hydrogens bound to the nitrogen.
(2) dichloramine has two chlorine atoms and one hydrogen atom bound to the nitrogen, and
(3) trichloramine or nitrogen trichloride has three chlorine atoms attached to the nitrogen atom.
Now, if you allow NCl3 to form you are setting yourself up for a disaster if the NCl3 concentrates up. First, many lifeguards have become sick due to formation of NCl3 in chlorinated indoor swimming pools. The ammonia comes from urine in the pool water. Second, in the 1930's and 1940's NCl3 was used to bleach flour. Some pet food manufactures continued bleaching flour with NCl3. However, the practice has stopped because chloramines are linked to mental disorders such as alzheimers.
Here is the best part. The holy grail in the chlor-alkali industry would be a technology that can remove chloramines from chlorine. Several chlorine plants have exploded due to NCl3.
NCl3 has the detonation velocity of C4. Likewise, it is shock sensitive. Since it is well known that NCl3 can be decomposed with UV light, several chlor-alkali plants reduce the level of NCl3 with UV lights to avoid an explosion during liquefaction or in the tail gas.
So if you expose NCl3 to UV light or drop a container containing a very small amount it will explode.
If you would like more information on NCl3 please see my US patent # 5,832,361 at US Patent and Trademark Offices website.
I have a wealth of information regarding chloramines.
