I recently conducted at test of a chiller. The motor is hermetic. About 175 HP, 480V. Test at 75% load.
Vibration data showed shaft speed harmonics with 2x (not 1x) slip X #poles sidebands.
Current signature showed slip X pole sidebands 50 db down.
Current waveform shows a sinusoidal notch on each phase at the peak. The notch drops the left side of the peak.
This appears to be a rotor bar issue but I have two questions: What would cause the notch on the current waveform and why 2x rather than 1x slip x pole sidebands on the vibration spectrum.
Thanks for your comments.
