We had an oil level switch failure on a 300 ton air cooled chiller that was apparently caused by "excessive water flow".
The excessive water flow caused the refrigerant oil to flash and migrate from the evaporator to the condenser. If chiller is fully loaded there isn't a problem. when the chiller is satisfied and the a or b circuit is shut down the water flowing through the evaporator barrel flashes the refrigerant to a vapor that migrates to the condenser. When the chiller prepares to restart the second circuit of the chiller due to increased load the oil level switch fails causing the failed circuit to go into alarm.
Can someone exlain how this happens?
