Hello all,
If I've come to the wrong place with my issue, I apologize. However, I can't think of a more knowledgeable group on this subject. I've been developing a chemical dispersal system at my university and have come to a wall in the design process, with the necessity for a valve.
Essentially, I have a 30 psi pneumatic compressor that forces compressed air through a jet nebulizer (Pari trek S). A thin layer of fluid is aspired from the reservoir and aerosolized by the force. There are a number of solvents and alcohols that are aersolized, and leave the nebulizer reservoir as a vapor of 0.5 - 5.0 micron diameter droplets (to facilitate evaporation- essential to the design). I've found that even as little as a 0.1 psi restriction in the outflow severely reduces the ability for the jet to operate (by testing low cracking pressure check valves). As an open system will permit evaporation of the solution in the reservoir, I have been looking for a suitable valve for the outflow port that's normally closed until the system is to disperse.
There are a couple constraints for the design, and they include the use of low battery power that does not permit the use of a higher-pressure compressor, low cracking pressure check valves provide too large of a pressure drop and restricts the amount of aerosol produced, and the micrometer opening of the diaphragm (of the low-cracking pressure check valves I've tested thus far) is restrictive enough to cause the vapor to condense back to a liquid and cause sputtering.
I have looked at numerous valves and have not been able to find one suitable except for biochem-fluidics rotary valve with a 12-volt stepper motor. This is rather expensive and I would rather use this as a last resort.
I've also been looking at air-operated valves but cannot find a suitable valve with a low enough pilot pressure (all I've seen are 40+ psi) to be used with this system.
If anyone can provide their insight or suggestions as to a particular valve that would be suitable, I would me most appreciative.
Kindest regards,
Kyle
Kindest regards,
Kyle
