Objective: redesign existing pilot adjusting needle to regulate pressure. The timer cap that controls the needle:
I would like to know the following if you have had the experiences in this kind of pump design:
1. How many type of needle (pin) designs to control the pressure with a timer cap? (As much I know, there would be "slope" needle (no seals o-ring required, but you have to tight very hard to seal), and "dent" needle (seal teflon o-ring is required, but teflon will cracks over repetitive dent contact)
2. If it is the slope type, how do I calculate the needle (pin) slope, thread versus, pressure regulators, and timer cap (turning knob) relationship? Does anyone has some formula or calculating methods to share?
3. Which design is the most efficient as far as pin design?
Thank you so much so much for anyone who has any idea what I am talking about.
