Andries, thank you for raising this issue.
From the responses one realises that the problem has many aspects to it. I’m sure the problems being highlighted on this thread are being experienced worldwide.
I’d like to relate the situation experienced by me with regard to analysis report checking and what I call “gate-keeping”, or lack thereof, of company methods and processes being used to substantiate structural designs. It would appear that those checking other engineers’ work do not have sufficient knowledge of “what” they should be seeing. There is no point in checking another person’s numerical accuracy if the checker doesn’t know how the analysis should be done in the first place.
There are 4 signatures on final certification reports. They are: - (1) original analyst, (2) peer checker, (3) lead stress engineer and (4) department manager. Only the peer checker does a half-decent job. If he’s not experienced enough, mistakes and application of incorrect methods are not picked up. The lead “trusts” the peer checker and the manager “trusts” those below him to have “caught” any bugs/errors there may be in the analysis.
The company has been around a long time and are still providing daily repair support to their products that have been in service for 30 years or more. These old structural analysis reports contain stress methods that are clearly origin-referenced and any deviation from the standard is explained and justified. Needless to say they are all hand written and where early computer methods were used, a complete set of printouts necessary to replicate the calculations is provided.
However, a change has occurred with the advent of work-station automatic stress analysis methods and primarily the use of VB-based spreadsheets. Every component now gets its own dedicated multi-worksheet workbook that produces MS values at predetermined critical areas of the component. Most often that spreadsheet can only be “run” by the creator/analyst. It rarely is accompanied by an explanatory “front sheet”. The checkers therefore have to be familiar with the workings of the workbook or it can’t be checked. The problem is aggravated when these spreadsheet/report combinations are handed over to MRB/sustaining.
The company has its own structures manual, which is an excellent reference document based on classical analysis theory and each subject entry is backed up by a report outlining the theory which it is based on and, where appropriate, laboratory test reports.
The fly in the ointment occurs however, in that many of the stress engineers don’t know what the structural manual contains and the implications and/or limitations of the methods presented in it. The more complex analysis methods can be performed using online program versions of the method. However, some of these are often blindly used to solve problems that that do not always conform to the original analysis assumptions made. A similar problem exists with the “Roark Formula Grabbers” as I like to call them.
Another project-based, primary assembly item phenomenon called “The Stress Guidelines (or Methodology) Document”, has reared its head. (This form of document is now apparently widely used in the Industry) This document contains the stress methods that shall be used by the stress engineers. These documents often contain questionable methods that do not appear in the public domain literature or the company structures manual and are therefore not covered by in-house supplementary substantiation reports.
As examples amongst others, at a detail level, there are two frequently occurring problem areas that are not captured by checkers. The first is the application of bolt group analysis to joints that do not comply with the assumptions which bolt group analysis is based on. The second is lug analysis that suffers from the same problem.
Bolt Groups: Items that should be calculated as multiple support overhang beams are treated as a bolt groups. The flexibility of members between fasteners in the joint excludes the necessary assumption that fasteners further away from the bolt group centroid carry more load than those close to the centroid. In fact the opposite is most often the case.
Lugs: The in-house method used is based on the widely-used Melcon/Hoblit method, not Ekvall. Stress engineers incorrectly apply force systems that ignore the geometric symmetry definition of the axial and associated transverse in-plane axes. In a recent case a non-symmetrically placed bearing was analysed with the in-house lug analysis tool as if it was symmetrical. Out-of-plane offset moments caused additional stresses at the critical section behind the pin. This resulted in a substantial MS reduction. Three tiers of checking did not pick up the error.
While the above examples have not (yet) resulted in serious failures, margins have been dramatically reduced that will affect MRB and/or sustaining engineering functions down the line.
Are similar problems being experienced elsewhere? How are they being dealt with?
Ed.
