Shinouz... also...
CAUTION. Inserting the razor-sharp-flutes of a drill/reamer-bit into a hole is guaranteed to produce length-wise bore scratches, which can grossly shorten fatigue-crack initiation time and reduce the overall fatigue-life of the assembly.
NOTE. Inserting the shaft-end [smooth-end] of the drill/reamer-bit into the hole may work "OK", assuming that the shaft is burr-free. HOWEVER, IF the shaft is burred [IE: due to drill-chuck scoring], then the burrs will also score the hole walls, same as the drill-bit flutes.
Best plan is to use go/no-go hole pin-gages with a perpendicularity check-block.
Regards, Wil Taylor
Trust - But Verify!
We believe to be true what we prefer to be true.
For those who believe, no proof is required; for those who cannot believe, no proof is possible.
