jimo14;
As you have already probably ascertained from each of the responses you have received, there are as many opinions for this as there are writers.
Ralph Shoberg, RS Technologies, Ltd. has a recent very unique paper on this very thing. Dr. Shoberg's lab performed most of the torque testing for John Bickford. Dr. Bickford's Handbook on Fastening (The Bible in the fastening industry), ch 7, page 262, states: "Inspection torque is always applied in a clockwise direction.....the reason for this: the torque required to loosen it is usually less than the torque required to tighten it......the torque required to loosen a UNC thread is usually 70% of that required to tighten it.....for a UNF thread it is only 89%. That chaptrer makes very interesting reading.
Dr. Shoberg now does what is called an M-alpha plot with his equipment which will actually allow you to determine the actual energy going into making the joint and the actual residual clamp left.
Ingersol-Rand also has a piece of equipment that looks like a common torque wrench but is used only for torque auditng. I tell all my students that torque auditng, at best, is very complicated and very unpredictable.
Ford Motor Co. spent several hundred thousand dollars to verify that very thing back in the 60's.
Dr. Shoberg's web page is:
It contains a lot of good info on this topic. I am sure he would be glad to send you a copy of his paper. Bill P.
CSFT, Inc.
