ukd
Chemical
- Jun 15, 2006
- 20
I am using a 8" 1500 # dual plate check valve (designed accordance to API 574) for well stream (2 phase) and the valve vendor dont know the Cv vaue but they come with the bore size of 137 mm.
a) I used HYSYS pipe segment to find the pressure drop and they have 4 check valve types viz swing type,disc type,ball type and lift type.I wonder which type this check valve type comes under?
b) When I calculate the pressure drop across it, Is it correct to use net clearance (bore size) as I think when the valve is 100% open, there will be restriction in the plates?
c) Is there any restriction of the minimum bore ID for the check valves like the requirement of minimum bore ID of the reduced bore valves (API 6D)?
Appreciate to your response!
UKD
UKD
