We have 4 running centrifugal pumps. Each pump is equipped with 8” minimum flow recycle line. Each recycle line has flow control valve and check valve (downstream of the control valve. All 4 pumps discharge into one common header, 24”.
There will be additional 5th pump identical to the other 4 pumps and connected to the same 24” discharge header. Unfortunately, this new pump came without check valve downstream of the minimum recycle valve.
We need to start up the new 5th pump but in case this pump shutdowns or trips the minimum flow recycle control valve will fully open. My question is: will there be major pressure disturbance in the 24” disparage header? Or the other running pumps will work to maintain stable pressure in the discharge header?
Note: we need to start up the new pump but we are planning to add check valve after sometime from pump start up.
