Check valve and a Butterfuly valve combo
kah1873
I am looking for a manufacture/supplier of Check and a butterfly valve combination valve. Also the supplier of back flow preventor valve.
You may be thinking of an Adams pump start valve?
By back flow preventer do you mean reduced pressure zone device for preventing contamination of a water supply ?
Geoffrey D Stone FIMechE C.Eng;FIEAust CP Eng
Thanks, I was able to secure information on back flow preventor valve.
I have just seen once a check/butterfly combination valve built by Mokveld.
This combination has the bad disadvantage, that you can not replace the check valve without draining and depressurizing the system.
You also have a very special item in your system instead of two "standard" itmes.
Try to contact a check valve manufacturer like Noreva and see if they can offer a butterfly together with their check valve as a package.
