Check-Mate failing on my part file
baltozo
Automotive
There is one error: "Found 3 objects of type/subtype UF_faceted_model_type/3 NOT Permitted on WIREFRAME Category"
And my layer settings do indicate that I have 3 entities on layer 2. I want everything on layer 1.
I can't find the entities on layer 2!
If I select all to edit object display, it says everything selectable is already on layer 1.
I can't successfully run "Organize File" from the same toolkit because it takes too long. Just keeps flashing "Updating Objects". I waited 45 minutes and it wouldn't complete and I wasn't sure if that was going to fix the problem anyway.
The file is one large parasolid assembly with nothing but "Body" features in the Part Navigator.
Thanks in advance for your help.
I've figured this problem out already. Evidently, I placed entities on layer 2 and some lightweight faceted bodies got created. I was able to move those entities to layer 1 with the "inquire" program.
