hi!!
i am a bit confused about charge cooling and the resulting increase in volumetric efficiency.
in a pfi engine there is an air flow sensor upstream of the fuel injector. this sensor tells the ECM the amount of air going through. based on this input the ECM then directs the injector to inject fuel such that the A/F ratio going in is about stoichiometric. but the fuel evaporates off the intake valve and thus cools the air as a result of which the density of air increases and "more" air goes into the cylinder increasing the volumetric efficiency. but then that means that there is more air and less fuel so the trapped A/F ratio in the cylinder is not stoichiometric but slightly lean.
is there a factor in the ECM look-up tables that accounts for charge cooling?? for a particular air flow rate does the ECM inject slightly more fuel so that the A/F ratio trapped in the cylinder is stoichiometric as amount of air going in will increase after charge cooling?
do DISI engines offer a volmetric efficiency benefit over pfi and how? because if the DI engine is running in homogeneous mode the fuel evaporation will cool the air inside the cylinder but how will that increase the amount of air going into or trapped in the cylinder?is it because of the unthrottled or WOT operation for homogeneous mode?
and finally how do DISI engines offer the potential for more torque over comparable pfi engines?
thanks in advance!!
alex
thanks in advance!!
alex
