I have an assembly of about twenty different components all laser cut from sheet. I need to get all the parts from a single standard sheet and the parts don't quite fit. The specific size of the parts is not critical so I'd happily simply reduce the whole lot by 5% if I could. The ratio of the parts to each other cannot change so making one part smaller to get it on the sheet won't work.
If it can be done, how would you go about it?
Thanks.
Thanks.
