Changing Drawing Sheet Numbers 1
Creigbm
161
Is there any way to reorder the sheets in a drawing file? In other words, I want to make sheet 2 sheet 1 and visa versa. I know there is a work around by editting the sheet format and change the number manually.
You can drag the sheets in the feature manager, This will update the linked note "current sheet". You can also rename them on the sheet properties (right click sheet, edit format, properties).
