I understand what you have stated and have been doing things exactly this way. However, on some intricate sketches, there may be many dimensions required to make the sketch fully constrained before a driven dimension becomes an option. If I know some segment requires a driven dimension before I start, can I not create this driven dimension until after the sketch is fully defined?
The help file (driven dimensions) states:
"Only normal dimensions may be edited. To convert driven dimensions to normal dimensions, select the Style box, then click Normal. To avoid overconstraining the sketch, you might need to convert other dimensions to driven."
What is the Style box? Is this the same as the style editor?
