Changing Default Dialog Box
  • Thread starter Thread starter Barbod
  • Start date Start date
B
Barbod
Guest
If you had multiple drawings open in several different places, when you would hit save on a particular drawing, the open dialog box would go to the directory of the last drawing opened. Is there a variable or a way to change?
See REMEMBERFOLDERS system variable. And I also you can modify the shortcut on your desktop. Right click on the AutoCAD shortcut and select properties. In the Start in: Box enter the path on the pc or the network you want every dialog to open up to.
