John, Thanks for your suggestion. I have created a macro to change unit of dimension. I am also applying other values like colors, arrow size, text size etc., as per company standards along with unit change through same macro. Only thing was pending is dimensional tolerance unit is unchanged. At this stage I am little bit ok and my pending work is to change unit for dimensional tolerances.
Moving further I have another concern is , In drawing, few dimension with tolerance and few without tolerance. But while selecting these dimensions, I can’t differentiate these. This results in, it will apply tolerance to all dimensions including those don’t have tolerances previously.
So while creating macro, what I did is, put filter selection for dimension and select all dimensions by crtl+A. And now values are applied under tab lines/arrow, lettering and unit but avoided to go on tab dimension.
Is there is any way to apply selection filter to dimension with and without tolerance by using journals.
