change origin
alkemixt
Aerospace
Is it possible to change the origin of the part after the part has been created?
I was wondering if i can make all parts to have the same origin in an assembly.
thank you
you may find it useful to create a separate part which has just the three main planes (XY, YZ, ZX) in it, to which you (a) snap the other parts' respective planes, and then (b) Apply a "Fix" constraint.
This way, each of the parts is fixed to the same origin.
You can use this technique to properly position components with any plane you'd like.
